05-07-2013 04:36 AM
hi all,
im a student performs my final project. Briefly, i generates pulses with pulse generator , square wave 5V/ 100hz, to a transmitter-receiver pair of ultrasonic
transducers.
My aim is to measure the distance between those transducers. I want to synchronize the pulse generator triggering with the data acquisition from the ultrasonic
receiver, while pulse generator exceeds 4V (ch 0) , record x samples (ch 2). i tried to sample the two signals( square wave and Ultrasonic wave) simultaneously
and noticed for time delay between them.
i have labview 2010(student edition) and advantech PCI1714UL ( 4 single-ended analog input channels, up to 10Mhz sample rate) with advantech vi's for labview.
thanks alot,
gal.
05-12-2013 09:55 PM
What is the question?
05-12-2013 11:23 PM
how can i sample the Ultrasound signals exacly( with the error of the A/D) from the same point while using the Ultrasound pulse generator and labview?
thanks alot, Gal.
05-14-2013
07:29 AM
- last edited on
11-19-2025
02:26 PM
by
Content Cleaner
Hi gal.co,
Sounds to me like you are trying to achieve triggerable, synchronized input and output?
I suggest looking through this white paper: Timing and Synchronization Features of NI-DAQmx.
Also, National Instruments does not support the third party Advantech devices. If you require further assistance with the Advantech VIs, I suggest contacting Advantech. It does not hurt to post on the National Instruments forums, however, as other National Instruments customers use various third party drivers and could offer assistance.
