Synchronize sampling of rpm using frequency counter with force (voltage) signals
I have a VI attached which converts the voltage values measured from the ATI force/torque senosr to force values. I would like to integrate the measuring of TTL pulses from an RPM senosr. There is a bug with my current program, as the RPM value only updates once. If I put the read VI in a while loop, the program returns an error. How should I modify my code to solve this, and as well as to synchronize the recording of data from both sensors?
I have no prior labview experience, and really appreciate any help.
Message 1 of 1
(2,244 Views)
