Synchronize two VI
I have one simple question. For my project I am working with a high speed camera and a spinning unit consisting of a motor. I have two seperate VIs for controlling the camera and the spinning unit. I control the spinning unit with the help of a control board using VISA read and write.Camera is controlled by vision developement functions. Now i want to combine these two VIs into one and synchronize their working. Controlled board is pre-programmed such a way that when we write command "11" to it , the spinning unit starts its motor and sends an external trigger signal to the camera to start working. Now I just want to do this in one single VI (both starting of spinning unit and camera accqusition). I am attaching both the VIs for the reference.
Regards.
(3,737 Views)
If I understand correctly the camera vi is waiting for a signal of the motor vi. You could use queues for that (like a producer-consumer). If you add a timeout to the "Dequeue"and "Enqueue"-functions you can execute the Vi even if there is no new element in the queue.
Hope that solves your problem.
Anna
Anna Vogl
Certified LabVIEW Developer
(3,682 Views)
(3,681 Views)
Thanks I´ll give it a try.
(3,676 Views)
