Synchronized Copy Paste Between 2 VIs
You can also pass data to the UI loop/handler code via queues, notifiers or user events. I tend to avoid using references since that couples the UI with the business logic. However if the sole purpose of the subVIs is for UI manipulation then I would use references.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 11
(273 Views)
