Currently, on a 1075 PXI chassis, I am using a 7976R with a AT1212 pulse generator adapter to produce pulse patterns and read them on a 5764 Digitizer.
If possible, I would like to synchronize the two cards so that pulse generation and acquisition happens on the same trigger. However, I read that 7976R does not support NI-TClk libraries. The 7976R + AT1212 operates at a clock speed of 156.25 MHz, while the 5764 operates at 125 MHz.
Are there any alternative methods for synchronizing these two cards?
Thank you
