Synchronizing Multiple Waveform Graphs
I'm sending some data generated in LabVIEW 7.0 to a 'C6701 DSP using the TI DSP Integration Toolkit. I then process the data and send the results back to LabVIEW for display purposes. I am noticing, however, that the waveform display of the input leads the output waveform by a good bit (Meaning that by the time the output waveform is displaying, the input waveform has already updated to a new set of data). This is causing a number of problems. How can I have both of the waveforms update at the same time?
(2,706 Views)
You can use a wait function and find a suitable wait time before you display your input data. In the meantime, the data gets processed and output waveform is displayed almost at the same time as input waveform. A much better option would be to use two shift registers to store the input and output data and display them on the next run of the loop.
Ankita A.
(2,706 Views)
