Synchronizing PXIe-6361 AI with XNET-CAN
Hello everyone,
I have a PXI chassis (PXIe-1073) with two modules inside: one PXI 6361 and one PXI 8512 module. And would like to synchronize one analog input of the PXI 6361 with the XNET card (which receives CAN messages). Unfortunately I didn't find any examples for my case. Has anyone already experience in this?
Thanks for your help!
Chris
Message 1 of 8
(4,193 Views)
Can you explain what do you mean by synchronize ? Start receiving CAN Messages once the AI signal reaches a predefined value as a sort of trigger....?
CLD Using LabVIEW since 2013
Message 2 of 8
(4,173 Views)
Hello kartiknattar,
I would like to measure the position from two different devices (sensor and reference). The sensor communicates via CAN and the reference is connected to the input of the DAQ module. I want to synchronize the data, so I can get the deviation of the sensor signal.
Message 3 of 8
(4,171 Views)
Hi Zweimercedes,
Have you found any example on this? Lately I have met the same request from my customer. If you have any clue or material, would you please share with me?
Thanks in advance!
Zhaoyong Wu
Message 4 of 8
(4,134 Views)
Hello Zhaoyong,
Currently I am not working on this project. But I found this example from NI which comes very near to my case: Synchronize XNET CAN with X Series DAQ
I also got one code from a collegue, which is working but it's written in CVI. I can tell from the code that it's all about the initialization of the DAQ and XNET.
Kind regards,
Zweimercedes
Message 5 of 8
(4,129 Views)
Thanks Zweimercedes!
This is really helpful for me to understand the synchronization mechanism. Actually my customer is seeking solution based on .NET language like C# and I haven't found any existing example. Do you happen to have some clue?
Thanks again!
Best Regards,
Zhaoyong Wu
Message 6 of 8
(4,126 Views)
Hello Zhaoyong,
I am not very familiar with C#, but I could offer a code example in C. I uploaded the c- and header-files to the attachments. You can view the c- and h-files with a standard code viewer. Wish you good luck for your project!
Kind regards,
Zweimercedes
Message 7 of 8
(4,120 Views)
This is helpful!
Zhaoyong Wu
Message 8 of 8
(4,105 Views)
