Synchronizing analogue and digital outputs
Hi all,
     I am trying to write two sets of data, where one is analogue and one is digital. But when I am running the VI, both the channels are not getting synchronized and the signals are having a time delay in between. I have attached the VI, expected output and the output that I am getting.
Can anyone point me in the direction of some examples that might help me or suggest solutions to this problem? Any help would be gratefully received!
Nijas
(1,843 Views)
HI,
Have a look for this 3 articles I will share with you,
Timing and Synchronization Features of NI-DAQmx
https://www.ni.com/en-us/support/documentation/supplemental/06/timing-and-synchronization-features-o...
How to Synchronize NI-DAQmx Analog and Digital Tasks In LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy1CAG&l=en-US
Synchronizing Analog Output and Digital Output Signals Using LabVIEW with DAQmx
https://forums.ni.com/t5/Example-Code/Synchronizing-Analog-Output-and-Digital-Output-Signals-Using/t...
(1,795 Views)
     Thanks for your help, but unfortunately, none of these is working for me.
(1,733 Views)
