Synchronizing two 5421 AWG
I am using two PXI 5421 AWG's. The two signal generators have the same frequency but different amplitudes. I have a slide bar that controls the amplitudes on one end of the bar the amplitude of one 5421 is maximum and the other 5421 is minimum. At the other end of the slide bar it is vice versa. I am trying to synchronize the two signarotrs using Fgen-Tclk how ever I'm unsure how to use these functions,
(2,793 Views)
Hi l_m_s,
Have you seen this white paper on Signal Generator Architecture? There is some useful information on synchronisation in this document.
http://www.ni.com/white-paper/5535/en
I'll keep looking into this for you in the meantime, let me know if the white paper is useful!
Kind regards,
Matt H
National Instruments UK
(2,736 Views)
