Synchronous Messaging with User Events
Hi mcduff,
Yes, that is pretty similar to what I was envisioning, although I usually have each module/process/loop having their own pipeline (be it user event, queue, etc.) By the way, interesting looking icons on the "parse state queue" and "add states to queue"!
Message 11 of 27
(2,589 Views)
@Ben wrote:
unless there is some clear documentation. Imagine 15 or more parallel loops all talking on the same bus....
So if you use that approach and there is slight chance that Ben may be looking at the code, please document the intended connection and spare me the gray grey hair. Smiley Happy
Ben
That is why I wrote/added a logger debugger. It outputs to file that looks like this
Time       VI                 Command
0.000098   Main.vi_Ind        Macro: Initialize
0.000107   Main.vi            Macro: Initialize
0.000124   Main.vi_Ind        Data: Initialize
0.000134   Main.vi_Ind        Idle
0.000201   InstrumentLoop.vi  Idle
0.000206   DataLoop.vi        Idle
0.000332   UILoop.vi          Idle
0.109935   Main.vi            Data: Initialize
mcduff
Message 12 of 27
(2,588 Views)
@Gregory wrote:
Hi Ben,
Your self addressed stamped envelope sounds very much like sending the notifier to retrieve data with.
Are you saying Channel Wires are much better than Messengers? I admit I have not played with channel wires much
Yes but I use queues because I developed that approach before notifier etc were invented.
Nor have I !
But if I drop a constant and right-click Create Channel writer...
The dialog shows an image that looks a lot like what you are asking for.
And when they work the channel wire are much cleaner and it is very obvious what connects to what.
Ben
Message 13 of 27
(2,586 Views)
JKI State Machine has been updated. Dr JDPowell and mcduff14(my alter-ego) made some suggestions on git a while back.
mcduff
Message 14 of 27
(2,584 Views)
Here is snap shot of my template. Each process is independent, but all connected to each. That way you can message anywhere and anytime to anyplace.
mcduff
Message 15 of 27
(2,580 Views)
mcduff
While the logger looks to be helpful when debugging a running system, does it help when reviewing the code?
I would love to see a chart in the diagrams that indicates for each type of message (enum value) what is the source(s) and destination(s).
Spoiler
I am coming off of two project that I did at the end of last year. IN one case I was working to rewrite code that had used that approach but had become too complicated for my customers to follow and was a pain to enhance. I re-used one of the loops and tossed the rest.
The other one was again too complicated for the customer to support and they are asking for fixed price quote to rewrite it.
Now if the developers had included crass-matrix... I may not have been able to earn that money.
Ben
Message 16 of 27
(2,573 Views)
Yes. When having multiple loops talking to each other, it is good to see when the message was sent, and when it was processed. It also helped when I was repeating states that was not needed. The logger includes the Main/SubVI processing loop that contains the JKI SM. All States and transitions are recorded. I use the high precision relative seconds to record time differences since the millisecond counter does not have the precision, that is, a lot states look like they executed at the same time. However, I added the Event logger to my debugger in order to record FP Events and User Events. Unfortunately, the Event Logger use the millisecond timer and my states are not always in order due to the loss of precision. My logger uses a named queue to log the states, queues are perfect for many to one.
My programs are usually small to mid-sized, 100s of VIs. I usually have simple loop names like InstrumentLoop, DataLoop, UILoop, WatchdogLoop, GPSLoop, etc. So my enum basically matches the loop name, ie, Instrument, Data, etc, along with an Exit enum, that specifically starts the stop procedure.
One key when doing this type of messaging is making sure all the loops and User Event Structures are up and running before sending any messages to them. (I found this bug in my program with the logger.) If they are not running, the message is lost. This is where the forums are extremely helpful. I modified a VI by Brian Hoover that gives a list of all of the VIs running Event loops. Before sending any messages, I check the names of the VIs with the Event loops to be sure that they are running.
This is what it looks like. And yes, it has a sequence structure. 😉
mcduff
Message 17 of 27
(2,562 Views)
mcduff
AND OCCURENCES!
Nice.
Ben
Message 18 of 27
(2,560 Views)
@Ben wrote:
AND OCCURENCES!
Nice.
Ben
That is part of NIs Event Inspector Window, the VI EQD is password protected. Look in the folder that contains the Event Inspector Window. But I do have a special place in my heart for occurrences.
mcduff
Message 19 of 27
(2,558 Views)
I've marked Intaris' response as the solution - because it helps me get on with my task, but this is a good discussion and I encourage others to chime in with any input. Thank you!
Message 20 of 27
(2,547 Views)
