Synchronous Time Averaging
Hi all,
I wish to do synchronous time averaging where the signal is acquired if the trigger function detects a rising pulse from a tachometer.
My problem is when I add the current signal and previous signal together, there is no signal output after the add function.
I'm using a shift register to accumulate signals for every iteration.
Can anybody help me in solving this?
Thank you.
Hyin
(3,876 Views)
Hi Hyin,
adding something to an empty array results in an empty array...
You have to initialize your shift register (or use a case structure to handle the initial iteration). Right now your VI will start with an uninitialized (and thus "empty") shift register!
(3,871 Views)
Hi Gerd,
I thought when I add an array with an empty array will result in the array itself. How come it can become zero?
Can I know how to initialize the shift register? I try to add a constant outside of the loop, but it doesn't work as well.
(3,869 Views)
Hi Hyin,
adding arrays with different size (=length) will result in an array with the smaller size of both the input arrays, so adding with an empty array will always yield in an empty array...
You should use a case structure to avoid adding in the first iteration!
(3,865 Views)
Hi Gerd,
I add a case structure to pass the signal out when the iteration number is zero, and add the signal when the iteration number more than zero, and it works well.
Now I can do time averaging alrd.
Thank you very much!
I wish to ask one more question.
I tried to use the "time averaging function" in the signal express before and it doesn't do the right averaging. I mean it doesn't synchronize the signals when it perform the averaging.
Do you know why?
(3,859 Views)
Hi Hyin,
I don't use SignalExpress, maybe you should ask in that forum?
(3,857 Views)
