11-18-2019 08:17 PM
I have two cards (PXI-4300, PXI-4353) installed at PXIe-1071. PXI-4300 is used to measure voltage, which sampling rate is 2000. PXI-4353 is used to measure temperature, which sampling rate is 10. I use a while circulation with a cycle time of 2.5 s. I don't how to make sure that the two cards start sampling at the same time in each cycle.(Because it spends more time to measure temperature, so when PXI-4300 is done, but PXI-4353 is still sampling.)
11-19-2019 02:49 PM
We don't know what you tried because you failed to attach the VIs you used. Don't bother attaching pictures -- attach the VIs, themselves, please.
Are you using the PXI as a LabVIEW RT device, or are you running Windows inside its Controller? What version(s) of Windows/PharLap/LabVIEW are you running?
Bob Schor
11-20-2019 01:11 AM
Hi, Schor
Thanks for your response. I installed a controller(PXIe-8840 QUAD CORE, WINDOWS 10 64-BIT) to the chassis(PXIe-1071). I used LabVIEW 2015 to measure temperature and voltage. But I don't know how to achieve the process I mentioned before.
Now I use a Flat Sequence Structure to make sure the two cards start sampling at the same time, but it's not precise.
How to calibrate one card's clock by another one? How to get the clock of the card?
Thank you !
11-20-2019 07:45 AM
Pictures of small sections of code are useless to me. Imagine if I sent you a picture of 20 lines from somewhere in a 500-line C++ (or Matlab, or Python) routine and asked why my program didn't work ...
Does your PXI box have a Timing I/O board installed?
Bob Schor
11-21-2019 02:51 AM
Em.. Actually I haven't finished the LabVIEW code now, I just don't know how to make the two cards start sampling at the same time, the others are details.
I think my PXI board has a Timing I/O, but I am not sure, since I never used it before. The fig.1 and fig.2 are selected from the manual, could you please check whether it has or not?
Thank you!
Matt Fu
11-21-2019 09:00 PM
A PXI system typically has the following three components:
Can you provide a full description of your PXI system? What Chassis do you have? What Controller? What boards are plugged into which PXI slots? [In addition to providing the words to answer these questions, you could also include a photo showing your PXI box ...
MyPXI
Here's a picture of one of my old boxes. The Controller is in Slot 1, the Timing I/O board in Slot 2, and a Multi-function board (A/D, D/A) in Slot 8.
Bob Schor
11-22-2019 01:16 AM
My Chassis is PXIe-1071, Controller is PXIe-8840, two boards are PXIe-4300 and PXIe-4353.
Here is the picture of my PXI box.
my PXI box
Matt Fu
