Synchronously value change
Hello!
Please, if anyone can explain to me how you could do that all the indicators at the same time change the value.
In one program I have a problem when I change the language. The Captions of the indicators is changed synchronously according to the implementation of the loop.
I wish that all the indicators change when the value recorded the last indicator.
Please help.
Message 1 of 12
(4,440 Views)
I think you are looking for this.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(4,434 Views)
I have LV 8.6. :S
Message 3 of 12
(4,432 Views)
Here you go...
Norbert
Norbert
Expert: Geometry
Message 4 of 12
(4,430 Views)
We did not understand.
I have about 500 indicators, which can change the caption, and I would like this to happen simultaneously. Now, the caption changed with the implementation of the program - asynchronously.
This example, I deliberately put the timing in order to more clearly show the operation of the program as a function of time.
Message 5 of 12
(4,428 Views)
Sorry, but it is not clear what you are looking for (at least it seems that my example does not fit your requirements).
Please be more specific:
- How do you swap language (localize)?
- You are correct that for localization, we require to work with the caption of controls/indicators (as opposed to "the label"). But how is that connected to "value change" which happens only during runtime of the VI?
- What does your initial example show us exactly? I've seen a near to no-go (timeout of 1ms for event structure) and some "obscure timings in the Start Value Change event. You tell us that there is a purpose in this for-loop. But i don't understand that.....
thanks,
Norbert
Norbert
Expert: Geometry
Message 6 of 12
(4,426 Views)
If this Event was 500 indicators, which we want to change the Caption would be possible to see that the caption changed asynchronously and all the Caption does not change simultaneously.
Message 7 of 12
(4,422 Views)
Ok, so....
you have up to 500 front panel elements. All those show their CAPTION.
You want to distribute a function "localize" where the CAPTION of all those elements is going to change their values.
But you do not want to happen this "at once" but to change the CAPTION 'one by one'.
Is that correct?
Norbert
Expert: Geometry
Message 8 of 12
(4,419 Views)
No.
I wish that all the caption changed simultaneously and not in the range of about 100ms.
Message 9 of 12
(4,417 Views)
Jim
Message 10 of 12
(4,413 Views)
