Syncronize NI PXI-5412 and NI PXI-4462
I am trying to synchronize the operation of a NI PXI-5412 and NI PXI-4462. So
far I'm having issues between the two driver sets, and am unsure if I am able
to synchronize them. Only the 5412 supports T-clk synchronization so I can't
use this option, and I haven't found any alternatives anywhere. Thank you.
(2,965 Views)
Hello an123
Actually I was thinking that you can use the PFI ports to synchronize the devices. I found one document that might be useful to you: https://www.ni.com/en/support/documentation/supplemental/10/synchronization-explained.html
Regards
(2,934 Views)
