Syncronizing Multiple Time-Dependent Loops
Using labview 7.1 with the real time software I'm trying to syncronize three time-dependent while loops. Two are inside a for loop and one outside. I am able to use the "Syncronize Timed Loop Starts" function and the three start out in sync to begin with. However, I can't figuire out how to resync the two nested while loops with the outside while loop upon the next iteration of the for loop. I've tried using another "Syncronize Timed Loop Starts" function just for the two nested while loops but this doesn't seem to work.
(2,828 Views)
I haven't worked with timed loops, so I will make another suggestion - you can try using the functions in the Advanced>>Synchronization palette (for example, the Rendezvous VIs should help you).
If you want more help, you should probably post your VI.
___________________
Try to take over the world!
(2,796 Views)
Are your loops using the same timing source and input parameters? If you want each iteration to be synchronized, then the obvious solution is to use the same timing source and input parameters. Thus, once they start together, they will finish and start each iteration together.
E. Sulzer
(2,786 Views)
