Synthesis of time signal from Power Spectral Density Data
Is there a VI that does this?  I would like to use it to drive an instrument using my DAQ.  Typically PSD magnitude and frequency boundaries are specified.  Test execution uses a random phase, frequency, and magnitude performed over a specified time interval.  I appreciate any suggestion.
(3,149 Views)
Could you please specify a little more?
From my understanding you want to extract the time signal from your PSD, but I am not sure if this is what you really want.
In any case, there is some PSD VIs  if you look into the help >> find examples section, one of them might be the one you are looking for.
(3,061 Views)
The PSD does not contain phase information so you cannot reconstruction the time signal.
mcduff
(3,050 Views)
