Synthesis of time signal from Power Spectral Density (PSD)
Is there a VI that does this?  I would like to use it to drive an instrument using my DAQ.  Typically PSD magnitude and frequency boundaries are specified.  Test execution uses a random phase, frequency, and magnitude performed over a specified time interval.  I appreciate any suggestion.
Staffan
(3,600 Views)
Hello Staffan,
Thanks for contacting National Instruments.
National Instruments at this time does not have a VI developed to create a time signal from a PSD profile.  The signal processing tool palette has many functions for generating waveforms that could allow for you to program this application yourself.
If you are wishing to generate a particular noise profile, the Sound and Vibration Toolkit has a VI that generates a pink noise profile.
Please also feel free to contact NI to file an online product suggestion.  National Instruments takes these suggestions very seriously.
Browning G
FlexRIO R&D
(3,569 Views)
Hello Browning G,
I will study the information you provided and determine my prefered approach.  Thank you.
Staffan
(3,548 Views)
