System Exac have no privilege
Hi all
i have a CMD script (.bat file) that i'm trying to call from my LabVIEW application .
when i simplly ran the .bat file (by doubble clicikng the file) everythign runs perfectlly
when i try to call the same file, using the system exac function (from within LabVIEW) i get the folowing error :
System error 1314 has occurred.
A required privilege is not held by the client.
any ideas how to solve this issue?
thanks in advace 🙂
Reuven Stahl
Message 1 of 9
(4,972 Views)
Pls share the inputs, which you have provided for System Exec.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 9
(4,942 Views)
the entire command is the location of the .bat file, no other inputs are used
(i'm attaching a snippit of the relevent section of the code)
thanks 🙂
Message 3 of 9
(4,934 Views)
Try this!
Message 4 of 9
(4,920 Views)
system exac now return error code 2 (attached is an image of the error)
Thanks again 🙂
Message 5 of 9
(4,889 Views)
Hi Reuven,
We have a few knowledgebase articles on this issue, see if either are helpful:
Error 2 (Memory Full) When Using the System Exec VI
http://digital.ni.com/public.nsf/allkb/0F61A4BB5B9372CD862576AB007158F7?OpenDocument
http://digital.ni.com/public.nsf/allkb/EA1600EBA422E97286256AA20073C616?OpenDocument
Austin
Staff Software Engineer
NI
Message 6 of 9
(4,880 Views)
Hi all
thank you both for the helpfull answers 🙂
i found my syntax error in the cmd /c command and fixed it so now the script is running
but the script still returns "standard error"
thanks in advance
Reuven Stahl
Message 7 of 9
(4,866 Views)
Can you share the .bat file itself so we can reproduce your error and then look at how to solve this?
Message 8 of 9
(4,853 Views)
I'm thinking you probably have to run system exec with admin privileges.  I'm guessing that means running LabVIEW as admin.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(4,836 Views)
