System Exec always runs minimized?
I am running a labview code that runs a python script via the "system exec.vi".  I want the user to see the command prompt as the code runs.  This VI has input for "Run Minimized?", but it does not seem to work.  The script I am running takes a considerable amount of time to run and the command prompt actually gives an indication of how much time is remaining.  Is there a way for the command prompt to be displayed as the code is running?
Thanks.
(3,543 Views)
Did you also Wait until completed? you might need admin privledges
(3,535 Views)
I do have wait until completed on and I am an admin.
(3,510 Views)
When I use system exec and set "run minimized" to False, the screen appears.
LV8.6
Windows7
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,491 Views)
Accepted by topic author asdlkfjalskdjf
We will probably need to see some code.  enclude the py as txt
(3,489 Views)
