System Exec not working in executable
Again I must be doing something silly!
I am using System Exec to start/stop services. It works well on my development machine but on a standalone pc with only run-time license installed, it simply could not start/stop those services!
I did some research and found we have to configure executable or another alternative is to use .net to achieve this. Could I stick with System Exec to achieve this?
Many thanks
K Waris
ATE and Labview Consultant
https://www.easybodge.com
(3,665 Views)
Accepted by topic author k-waris
Sounds to me like a permission error - are you running as an administrator on the development machine, but as a less-privileged user on the other computer? Does system exec return an error (try adding a simple error handler)?
(3,639 Views)
