System Exec returns Windows error 193 on command requiring UAC, where it works on Windows CMD
I am trying to get a VI to create a scheduled task in Windows and having trouble with System Exec returning error 193 (Not valid Win32 application). If I copy and paste the same command as the error output says I executed to a Windows cmd prompt it executes fine, although it does pop up a UAC window for me to click Yes. This is in Windows 7. When I run the code in LabVIEW, it doesn't pop up the UAC and just gives the error. Here is the command I am trying to execute. The reason I am executing an .exe.lnk is because schtasks needs to be run as Administrator so I have created a shortcut with the property set "Run as Administrator" to call from System Exec since it doesn't seem to support running as Administrator on its own.
"C:\Users\britehappy\Documents\Projects\My Project\Source Code\schtasks.exe.lnk" /Create /tn ATU_Reports /tr C:\Windows\System32\calc.exe /sc WEEKLY /d MON /st 10:37 /f
(8,437 Views)
I decided to just give up and use the .NET process library instead to execute the command and it works just fine. I would still be interested in seeing any replies on how to get the LabVIEW system exec to handle this type of situation, however.
(8,428 Views)
Hey, if the comand works from the windows side, maybe some of your set up could be sending something different, how is your VI doing this?
(8,385 Views)
Is that the full command-line string you're calling/passing into System Exec? You would normally put a cmd /c "my command" (escaping the quotes from your command above) in front of it when running shell commands.
(blog)
(8,368 Views)
It may help to run the actual EXE and not the shortcut to the EXE.
(8,366 Views)
