System Exec.vi does not work in Windows XP
We have an application that works in LabVIEW 6.1 on Windows98. It uses the System Exec.vi to send a command line and read the standard output. When this was ported to LabVIEW 7 on a WindowsXP machine, it doesn't work. The standard output window in the System Exec.vi is always blank. Is this a known issue with either LabVIEW 7 or WindowsXP? If so, is there a workaround?
(3,105 Views)
I have used similar setup on XP successfully.  What's your command to the System Exec VI?
-Khalid
(3,099 Views)
Is there any error on the error out of sytem exec? Is "wait until completion?" TRUE (default)?
(3,092 Views)
Sorry, I left out information. The user running the application is actually in another state. It works fine for me in Windows2000 and Windows98 with LV 6.1. I did confirm from them that yes, there is an error code 2 in the System Exec.vi.
The vi is launching an *.exe with command line arguments. The exact command works in a DOS window and returns the exepected information in the standard output.
The working directory input is set to the path for this vi
The standard input is set to 10 "\n" (new lines). I honestly can't remember why. Hmmm?
expected output size is 4096
wait until completion is TRUE
run minimized? is TRUE
The user is now going to copy the application to a Windows2000 machine with LV 6.1 and test that.
(3,072 Views)
