System Identification Dc Motor model Estimation
Im using Qnet DCMCT board and i'm Trying to identify the motor while it's running to use online adaptive control.
but i dont know which System identification should i use, i used ARX Recursive SID but the problem with that is  the parameters are always changing and B(z) is not the same when i compared it with the theoretical values?
any idea  ?? Help
(4,551 Views)
With a recursive type of SysID the parameters should always be changing, that is the nature of recursion.
Also, the likely reason the values are different from theoretical is that SysID provides a close estimation of the model than the theoretical values, this is why Sys ID is used.
You might want to take a look at the Online Model Estimation. vi in the NI Example Finder.  You can find it under Toolkits and Modules>> System Identification>> Getting Started >>Recursive Estimation.
I hope this helps!
KristenH
(4,512 Views)
