System Replication Tools - Corrupt installation/image?
To replicate a NI-9074 I use the executable from the RT System Deployment Utility (rtcp.exe, ftp://ftp.ni.com/support/labview/labview_rt/SystemReplication/RTSystemReplication8x.zip)
The problem is that I get attached error message when I try to access the NI Web configuration pages when I deploy a full backup.
Taking a "Installed Software" backup, I get access to the NI Web configuration pages. But I must get the same error, but a refresh fixes this problem.
To be able to create a backup that supports both my project spesific files and the NI Web configuration pages, I have to manualli merge the two backups.
Anyone else having this issue or know why I have it?
(2,738 Views)
Looks like I reproduced the problem with deleting the tmp folder on the cRIO.
Does the "NI Web configuration pages" need files in tmp folder to work?
(2,734 Views)
Accepted by topic author paljacob
By using the latest version it seems to work fine.....
http://zone.ni.com/devzone/cda/epd/p/id/5986
(2,709 Views)
