System Resource - csrss.exe
I have recently been seeing a problem with my labview application (mixture of data aquisition / control running on NT) where csrss.exe hangs and takes up all of the system resource. There is a solution on the microsoft knowledge base which involves editing the registry, but would prefer not to have to do this. Does anyone have any experience of this problem?
(2,779 Views)
I have never heard of an error like this occuring with a LabVIEW application before and I have been unable to find any references to it on NI's website either. If you have found a workaround for it, I would suggest using that, although registry hacks can be tedious. Just make sure that you create a backup before making any changes to your registry.
J.R. Allen
(2,779 Views)
