System.Security.Authentication.AuthenticationException
I have to send an email through labview. but their is an error : System.Security.Authentication.AuthenticationException. please send me a vi for sending email through Labview.
Message 1 of 8
(5,129 Views)
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\Utility\SMTP\smtpeml.llb\SMTP Email Send Message.vi
Use the above function. Install the 'Internet toolkit'/ Data Connectivity
Yogesh Redemptor
Yogesh Redemptor
Message 2 of 8
(5,126 Views)
How about if I suggest instead that you actually try to do something that's a novelty in this day and age: Do a search.
http://forums.ni.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A170&q=e...
Message 3 of 8
(5,116 Views)
I have used  this solution  and i am getting same error again. here attached preenscreen for error msg.
Message 4 of 8
(5,101 Views)
Did you read this thread. I guess you may have solution there
Message 5 of 8
(5,099 Views)
hello ,
 i have used ur solution but i am getting the error again.
Message 6 of 8
(5,098 Views)
hello ,
Message 7 of 8
(5,098 Views)
Try disabling the windows firewall and then run. ( May not fix your issue but just a try)
Message 8 of 8
(5,096 Views)
