System Software NIAuth username restrictions
Just curious as I didn't find it documented in the help.
Are there any restrictions on username or passwords for niauth?
We had tried creating a username of "Manager" and realized after a day of debugging the username actually saves as "manager". Is this an intended restriction? The web configuration and management client will login successfully with "Manager". And you cannot create a second username of "manager". When we were trying to login with "Manager" using our javascript library it was failing. I haven't tried a system configuration session within LabVIEW.
I realized after that every previous username we've created is lowercase only but I don't recall landing on this issue before.
We are using system config 17.5 with labview 2016 sp1. We are using the niauth.js that someone had uploaded a few years back from this forum.
Example shows username as lowercase only
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LgPSAU&l=en-US
Kyle Hartley
Senior Embedded Software Engineer
(1,211 Views)
For those curious, this is the original post I found the JS from.
https://forums.ni.com/t5/LabVIEW-Web-Development/Using-NI-Auth-from-Javascript/td-p/3680229?profile....
Kyle Hartley
(1,163 Views)
