System date time format with LabVIEW 6.1
If I configured a numeric control as follow:
"Time & Date", "System Time Format" OR "System Date Format".
The problem is that I can't change any of the date and time value (hour, minute, second, day, month, year) with the keyboard. My change are never accepted.
If I choose "Custom Time format" AND "Custom Date Format", it is possible to change date and time values with the keyboard.
My system date is: dd.mm.yyyy
My system time is: hh.mm.ss (0-24h)
Any idea ???
(3,285 Views)
Hi
you can change time-format in LabVIEW as follws:
go to Tools - Options - Time and Date in menue bar
I use attached vi for showing time and date on
frontpanels.
Hope this helps
Regards
wha
(3,285 Views)
csch,
I have not been able to reproduce this issue. I can type in a new time or date and press . The new value it taken as expected.
I am running LabVIEW 6.1, Windows 2000 SP1.
Randy Hoskin
http://www.ni.com/ask
(3,285 Views)
Thanks for the help. I forgot to specify my OS.
I'm running LabVIEW 6.1 on Windows NT4 Sp6a.
(3,285 Views)
