System.drawing. image to system.drawing.bitmap
How can I convert a system.drawing. image to system.drawing.bitmap?
(5,508 Views)
Have you tried To More Specific Class?
(5,493 Views)
Yes I tried, but doesn't work.
I'm trying to do it in different way but I'm getting an error,
se VI annexed...
(5,459 Views)
Hey there;
You can check out this post; it has all the c code necessary to do so.. you can use it in LabVIEW with the Call Library Function node
Good luck
(5,383 Views)
I believe the constructor is the way to go.  What problem are you having?  Your example is going to fail since the PictureBox is empty, load a picture into it and try it then.
(5,376 Views)
Thanks Darik,
Yes I been working last days and works fine when I put a picture on it.
At this time, my application it's working: USB WEB CAM==> Take picture ==> decode Matrix code  (all without use Vision Package, just freeware .NET)
(5,371 Views)
