System error 10000050
after a few hours or days I get the following error that I attach here while my data acquisition application is running.
Any solutions?
Thanks.
(4,334 Views)
Hi tonitpp:
I need more information to find the reason for this problem. What program pop up this error window? is it labview?. What is the instrument model that makes the adquisition?. What kind of data do you acquire?.
I wait for your answer.
(4,304 Views)
The program that popup this error windows seems to be caused by my data acquisition application because is the only is running but also seems to be generated by other libraries of windows perhaps such as ole32.dll etc.
The instrument model that I use to make the acquisition is a NI PCI-6025E connected to other boards such as NI SC-2051 (To read/write digital i/o through two boards SC-2062) and NI CB-50LP (to read analog inputs coming from probes).
I acquire the data coming from probes through the CB-50LP (analog inputs 4-20mA) that is connected to NI PCI-6025E.
But as I said above, sometimes I get error message caused by ole32.dll, others caused by NI Service Locator (This service that is running in the background sometimes suddenly stops and I don't know), others are system errors, other Dr Watson.... etc. I don't understand....
Here I attach some message errors.
Many thanks,
Toni.
(4,298 Views)
another message error, I attach you here.
Many thanks for you help
Toni.
(4,296 Views)
I forgot to tell you the version I use:
I use LV 7.0 Express with Measurement & Automation Explorer 3 and Microsoft Windows XP SP2
Toni.
(4,277 Views)
