System exec failure
Please help if you can: I try to call an .exe file from within a LabVIEW application, using System Exec.vi. I get error 2: Memory is full. See the attached code for winword.exe, but any exe refuses to run.
(3,414 Views)
Somehow the attachment did not appear in my original message. This is a retry....
Message Edited by Peter Vijn2 on 02-09-2006 06:35 AM
(3,411 Views)
HI
I think U have to wire expected output size. Try that might be it will solve your problem.
(3,405 Views)
All that you have to do is put "C:\Program Files\Microsoft Office\Office\winword.exe" into the command line.
(3,399 Views)
That helped Dennis! Thanks a lot for your help. I just assumed that the directory path wired to System Exec.vi would automatically switch to the proper application. The 'Memory full' error didn't help much to solve, but I can live with that.
(3,374 Views)
