System state: IP Stack Configuration Error
I'm getting the message "System state: IP Stack Configuration Error" when I start up with Real-Time Desktop Validator.I read the following
Requirements for a Desktop PC as a Real-Time Target
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
How Can I Test My PC For Compatibility with LabVIEW Real-Time or LabWindows/CVI Real-Time for Desktop ETS?
http://digital.ni.com/public.nsf/allkb/82D66505D86349F38625722C00736AB8?OpenDocument
Real Time PC target ethernet problem
http://forums.ni.com/ni/board/message?board.id=170&message.id=214322&requireLogin=False
But I can not find a solution, any suggestion?
I´m using a configuration:
My processor is a Pentium 4,
hard drive is IDE (reformatted to FAT32).
Intel Ethernet 82550 (in the list of supported devices) I disable the extra ethernet chipsets in the bios and only have one available that is compliant with the desktop ETS system requirements.
I connected the PC to our network(which has a DHCP server)
(4,255 Views)
Hi eesen,
Which version of LabVIEW are you using?
(4,233 Views)
I solved the problem, thank you.
For people faced with same problem:
I reinstall OS with the USB utility disk  and I reset network settings, it started to work.
(4,220 Views)
Hello eesen.
I think to have your same trouble.
Could you explain with more details the way to solve the error with IP stack configuration?
Thanks.
Good moorning
(4,135 Views)
