Szukam przykładowej aplikacji LV zawierającej ....
Czy można znaleźć przykład aplikacji (" *.v i ") zawierającej syntezę elementu
dokonującego zliczania impulsów prostokątnego kształtu , wytwarzanego przez
wirtualny generator. Zliczanie powinno mieć postać cyfrowej wartości decymalnej.
Grizli
(1,349 Views)
Accepted by topic author Grizli41
Hi Grizli,
@Grizli41 wrote:
Can you find an example of an application ("* .v i") containing element synthesis
counting the pulses of the rectangular shape produced by
virtual generator. The counting should be in the form of a digital decimal value.
Mind to write your questions in Englosh in this English-speaking forum?
Did you even try to search for such VIs? Did you examine the example finder in LabVIEW?
What have you tried so far to solve your homework?
(1,318 Views)
I have tryed it, but I did,t found it.
I hope that problem may be simply , who has better knowlege of LV and is skill in it.
Therefore I attache my example to show my trouble.
Grizli
(1,287 Views)
Thank you for your project very much. It operate quite well, but I have to change it a little , compare to orygilnal.
Aftet it , that shape its signal has better stability, however I don,t knew why. That circuit I woud like to use for controll
steps motor and therefor I need to change shape of its signal as rectanguler shape. To obtain it, I try adapt it with
use the Derivate block, but I'm estonished that block don't operate well, Why - it is a question ?
If you will look at its project, you can see what is the reason of it.
I attache that circuit to sent you. If you pleased, give me some answer what can I inprove it.
Best greetings.
Grizli
(1,266 Views)
Sorry, it's my mistake...
I once again say :
Best greetings.
Grizli
(1,262 Views)
