TAB in a string not diplayed!?
I am using Labview 5.1 and I want to show a header
part of a file in a labview program. I display the
information using a string variable. There are
tabulators in the header string to separate the
information. These tabulators are diplayed as \t
if I use the "\"Code display setting of the string
variable. If I use the normal display setting the
tabulators are only displayed as blanks.
Is it possible to get working tabulators in a
labview string???
Mike
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(4,225 Views)
