TANK WATER CONTROL WITH KEYS AND SOUNDS
I need help to modify this program so that it fills and empties using keys and that it also makes corresponding sounds when pressing play.
I have already tried to do it on my own but I can't find a way to odify it so that it continues to do its job of indicating the level it is at with the booleans.
I hope you can help me.
(1,504 Views)
Hi gota,
0915gota@gmail.com wrote:
I have already tried to do it on my own but I can't find a way …
So what have you tried? Where exactly did you fail?
Why don't you attach your attempt to tackle that homework?
(We usually don't solve other peoples homework! We will help once the students show some effort of their own…)
(1,457 Views)
What I am trying to do is that in the circuit I implement the function of filling and emptying the tank with PC keys and that when it does the function it also makes sounds.
It's something similar to this:
https://www.youtube.com/watch?v=Ki7WFK667z4
(I didn't find a video about this in English)
(1,445 Views)
Hi gota,
I know what your homework requirement is…
But what exactly did you try by now? Mind to attach your VI with your own trials?
(1,436 Views)
I attached my progress in the first post, but I'll reattach it again
(1,425 Views)
Hi gota,
That basically is just the homework template.
  • There are no additional buttons or any attempt to read keypress events from your keyboard. (LabVIEW has functions for "events" and for "keyboard".)
  • There is no attempt to play some sounds. (There are functions dedicated to play sounds.)
So what exactly have YOU tried so far?
I recommend to:
  • do some LabVIEW basics training - as offered at the top of the LabVIEW board
  • play with the example VIs about event handling or keyboard inputs
  • play with the example VIs for playing sounds
(1,418 Views)
