05-31-2021 05:52 AM
I work with NI TB-2503 modules on which the TB-2605 module is connected.
On NI-max you can configure the TB-2605 on the TB-2503. I need to use it in 4 wires mode and I could do it until recently, but it seems that there has been an update and I can only choose, in 4 wires mode, the configuration: 12*1 Mux.
I can't read the values of my temperature sensor in this mode. Has anyone encountered the same difficulties? Is it possible to understand how to adapt to this change?
Best regards.
08-19-2021 08:13 AM
Have you checked the pinouts?
In this article, the correct architecture is described, maybe there is something you've missed.
Thx.
