TCL labview activex
I'm develloping a Labview program which uses a TCL shell for automation. The shell contains signal commands ( "puts" to acquire and "set" to generate) which must be executed by LabView. I have read that I can use ActiveX to do it but I don't see how and I'm not sure that it is the best solution.
If anyone can point me in the right direction, or give me an example of how to do this I would greatly appreciate it.
Guillaume.
(3,343 Views)
Hello Guillaume,
You can find, in the links below, a response to your question:
http://forums.ni.com/ni/board/message?board.id=170&message.id=37183&requireLogin=False
Internet Toolkit Troubleshooting Wizard
http://www.ni.com/support/labview/toolkits/internet/faq.htm
Sanaa T
Sanaa T.
National Instruments France
(3,305 Views)
