TCP Connection lost in between TCP read operation
Hi himanshu,
                                        I am receiving the data over TCP in hex format so binart string has no meaning & i may receice the data of size 2097170 in hex.
1 more thing check the link "File Synch Tool\Synch Tool-RTU\RTU File Transfer Code\Sub VI\RTU_Receive Data on TCP.vi"
i suppose this is the VI to read the data over TCP. but in second read also u r using the standard as mode of reading can you please tell me the logic of this..
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 11
(518 Views)
