TCP Data stream
thanks, it shows me now the first value (time). how can I get the second value (signal) out of the string?
Message 41 of 43
(1,129 Views)
Accepted by topic author lepina
Change the regular expression in the code I sent you earlier from "(.*)\s(.*)\s" to "([\d,]*)\s([\d,]*)\s". That will separate the values correctly.
You can also use the Spreadsheet String To Array that crossrulz suggested as well.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 42 of 43
(1,125 Views)
thanks a lot mark, now it shows me the diagrams with a time stamp on the X and the signal on the Y axis.
Message 43 of 43
(1,103 Views)
