TCP Error
Hi
I am using the TCP communicator Active to receive data from other computer. The problem is that at some time this program outputs wrong. I have checked using hyperterminal  and data is received OK in hyerterminal but Labview is nt giving me expectd data. I am using TCPcommunicator Active example provided by Labview.
As you can see in bitmap,all strings are OK but the first one is not.
(3,026 Views)
Hi arrowminds,
i see no problem with this example, did you change something?
Mike
(3,002 Views)
Nopes I didnt changed anything. I was also surprized on this wrong output. Anyways I will try to handle this issue.
Message Edited by arrowminds on 03-18-2009 02:26 PM
(2,985 Views)
