Showing results forĀ
Search instead forĀ
Did you mean:Ā
TCP Events are not processed on LabView RT
I am using LabView 7.1 on a RealTime target.
I want to do TCP-communication via a c-dll (with RegisterTCPServer(), ServerTCPRead(), etc).
I call ProcessTCPEvents() repeatedly, but the registered callback function is not called.
However, the client programm _does_ get a connection to that server... but there is no TCP_CONNECT event receiced, nor any other TCP events.
The same vi/dll on LabView/Windows - target works well.
Do you have any suggestions?
Thanks very much in advance!
Fabian
(3,408 Views)
Hi Fabian,
can you describe it a little more in detail and post a small example, which demonstrates the issue only.
Thomas.
(3,381 Views)
Thank you very much helping me! šŸ™‚
What i do is to create a thread (via win32 CreateThread()), that (should) handles all the actual tcp-stuff. The threadfunction is ServerFunction(), see below. All this is located in a dll, that is called from inside LabView.
It registeres the TCP-Server (successfully!), calls ProcessTCPEvents() and performs TCPRead and -Write functions, and finally closes the server.
What happens is, that the call to ProcessTCPEvents() returns -13 (-kTCP_GeneralIOError).
This occures, when executed remotely on LabView Real-Time 7.1; when executed locally, under LabView for Windows, it works fine.
Thank you very much for your help!
Fabian
--- source code: ----------------------------------
DWORD WINAPI ServerFunction( void* data) {
// register server
status = RegisterTCPServer( pServer->nPort, ServerTCPCB, pServer);
if( 0 != status) { // failed to register server
pServer->state = SERVER_ERROR;
return -1;
// run server
pServer->state = SERVER_RUN;
while( SERVER_RUN == pServer->state) {
g_TCP_Event = ProcessTCPEvents();
if( 0 != g_TCP_Event) {
// failes with -13
// ok, read, write data etc. ...
(3,374 Views)
Hi Fabian,
if I understand the online tutorial
http://zone.ni.com/devzone/conceptd.nsf/webmain/581daa037d5b440986256ebd00557d8c#8
in the right way, then
"You must call this function in a polling loop to process TCP events ...".
It seems a little different handled - compared to message based Windows. I can“t see differences
between Your and the discussed sample code ...
One different reason may be that the ethernet-controller is configured in a wrong way (Max >>remote devices >> myRT-Target//Advanced Ethernet Settings)
Hope this helps,
Thomas.
Message Edited by Tobel on 01-10-2006 08:41 AM
(3,366 Views)
