TCP/IP 1 server with multi client
i want to create project that has 1-server for multi-client, send data,log in system and register system.
Part of send data,log in system and register system has finished,But it can send only 1-server to 1- client.
Can anyone advise and point me in the right direction?
(6,764 Views)
Typically, you'll have a TCP\IP Listener. Once it gets a connection, it starts a cloned dynamic VI to manage that connection. The listener would simply continue to wait for new listeners.
(6,743 Views)
Help >>> Find Examples >>>Networking >>> TCP & UDP >>> TCP Multiple Connections.lvproj
Ben
(6,734 Views)
Thank you.I had watched,But  i can't adapt it with my project .Because I want to use a lot of port and i want to transfer a lot of data .
(6,720 Views)
Ben
(6,720 Views)
Can you give me an example?Plz.
(6,719 Views)
Can you post a screenshot of your existing code or explain further why a program based on that multiple connection example can't be adapted to your project?
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
(6,693 Views)
