TCP\IP Error 63
Hi all,
Objective: My first goal is to establish communication between two PC's using TCP\IP and second goal would be to
               send a text file from one PC to another using TCP\IP.
Current Status: I have one PC which I am planning to use as a server (LabVIEW PC) the another PC, I am planning to
                       use as a client, which is located in another department but it is connected on the same network
                       (Department PC).
LabVIEW Code used: I am using two Labview VI's from NI example. These VI's are Simple Data Server.vi & Simple Data
                                 Client.vi
Problem: I would run Simple Data Server.vi first and then Simple Data Client second as described. It works great if I
              specify the address of (LabVIEW PC) in Simple Data Client.vi. However once I put the address of my client PC
              (Department PC) I would receive an error, specifically Error Code 63.
Verifications: I double checked the Firewalls on both PC's and they are turned off. I can read the IP address of my client
                    PC ( Department PC) using "String to IP" & "IP to String" functions. Original port setting is 2055, even by
                    changing the port setting on the Simple Data Client.vi to 2056 it did not make any difference.
Note: I am working wit LV 8.6
I would really appreciate if you could help me out on this problem.
(5,475 Views)
Can you try running both the client and server on the Department PC?
Error 63 means the connection was refused. Maybe there is something else already listening on the ports you tried.
LabVIEW 2012
(5,459 Views)
