TCP/IP Link
Hii All,
I have developed a application with TCP/IP links but i got error no. 56 (Time out).
Can anybody tell me what i did wrong in the same.
With Regards
Puneet
(3,402 Views)
We would need more details before we could give a reasonable diagnosis. Please post your VIs if possible, otherwise some screenshots...and a detailed description of what the code is doing when you get the error. What version of LabVIEW are you using?
(3,398 Views)
Here is VIs attached ..pls tell me the solution..
(3,395 Views)
Error 56 is thrown by your application, when it does not receive a network response in the defined time limit.
Read this link to know more about this error and other related errors
This link will teach you how top develop a simple TCP/IP communication code
Any doubts, do ask
Dev
(3,384 Views)
You're converting the timeouts to warnings everywhere except during the TCP/IP WRITE, pIease send a screenshot of the error message so we might tell where it's happening.
(3,378 Views)
