TCP/IP address
hello.
First excuse me if I will ask a basic question. I would try to communicate with a spectrum analyser ANRITSU via RJ45 ethernet, by using the visa library. So I'm using the example provided by the document. The probleme is that I need the TCP/IP address of the instrument, but I really don't know how to get it. I would be happy if someone could tell me how to do.
Thank you very much for your help.
Jojo
(3,003 Views)
You set the IP from the instrument's menu if you want a fixed IP. I think it also supports DHCP so if you have a DHCP server, it will get it from that. Then you should be able to get if from one of the instrument's menu. This should all be documented in the manual.
(2,996 Views)
thank you very much for your quick answer. I willl follow your advice as soon as I will receive the spectrum analyser. Thank you very much
(2,992 Views)
