TCP_NoDelay.vi not working on LabView RT
This VI is not available for LabView RT.
The subVI GetRawSocketFromConnectionID.vi
(5,192 Views)
I understand now that this property can be changed by a VISA resource ( see Example ) but am having trouble choosing the right VISA resource to see the effect of enabling or disabling the TCP(IP No delay.
(5,186 Views)
This article discusses the Nagle algorithm in Labview
The example program allows the TCP No Delay property to be changed in LabView
In the mean time you will see I have learnt to define a TCP/IP VISA resource
On Windows the delay time is reduced by setting the no delay property to false
In LabView RT an error message occurs when setting delay property to false
Property Node (arg 2) in NagleDemo-MessageSenderVisa.vi
VISA:  (Hex 0xBFFF001E) The specified state of the attribute is not valid, or is not supported as defined by the resource.
My question now > Why can I not set No Delay to false in LabView RT?
Thanks, Louis
(5,180 Views)
hello louis,
on RT systems the nagle-algorithm is always enabled. there is no way to diasble it.
regards,
robert h
NI germany
(5,137 Views)
Thanks and it seems our problems lay elsewhere.
We can now send 20s of data at 1kHz over TCP/IP without having 400ms windows of data arriving late.
Simply had to not send data to the front panel so often - still learning how to efficiently program in LabView RT.
Bye, Louis
(5,131 Views)
All-
These VIs do not work on Real-Time systems.  As of LabVIEW Real-Time 8.6.1, this algorithm has been turned off by default and there is no way to turn it on.  This information comes from the Real-Time R&D department.  This behavior was filed as a Corrective Action Request (CAR 123312) which was fixed with the 8.6.1 release.
Message Edited by George P Burdell on 02-15-2010 02:22 PM
Mike S
NI AE
(3,930 Views)
