TCP Read with custom message termination symbol (LF instead of CRLF)
QFang,
This is an interesting conversation, though I'm afraid I'm hijacking the original thread. What I really want to know is what this mysterious little shape is. lv image.jpg I've been using LV since version 1, but I was away for a few years and I'm having fun discovering all the new and wonderful things. Is this simply a new icon shape that I can't find or does it have something to do with inlining the VI?
Clay
Message 11 of 18
(2,622 Views)
Are you sure? I could have sworn I got timing related "issues" in some other code when I inlined the wait, which went away when I structured it?  Maybe I was a ghost hunter seeing ghosts where there were none?
QFang
CLD LabVIEW 7.1 to 2016
Message 12 of 18
(2,612 Views)
Clay, in the icon editor, if you delete the entiere icon, then draw a smaller contigous shape, anything you don't "enclose" will be transparant.
So the shape you see is nothing but a quick drawing in the LabVIEW icon editor, leaving most of the space "empty".
I find this feature incredibly useful to create small "in-line" style icons, for example if you have a sub-vi that do wire-level operations it can really help make your diagram wires straighter.  That said, on a percentage basis, I rarely use this feature.  I think this has been around at least since LV 7 but I can't say for sure. 😉
QFang
Message 13 of 18
(2,610 Views)
I decided to make this into a community Example / Tutorial.
You can find the document here:
https://decibel.ni.com/content/docs/DOC-31512
QFang
Message 14 of 18
(2,578 Views)
Hi Riley,
sorry for reopening an old post.
Are you sure termination char will work also with TCP communication?
Message 15 of 18
(461 Views)
Yes, it will work. Using VISA, of course.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 16 of 18
(457 Views)
Hi Paolo,
do you mean that I have to use VISA Properties just before a TCP Read?
So, how have I to parametrize TCP Read? What input should I choose in    "mode(standard)"  input?
No, I cannot understand how to use VISA over TCP communication.
Please explain me better, or show me an example, please.
Message 17 of 18
(448 Views)
What Riley was speaking about is TCP communication using VISA, which is possible.
Did you ever use VISA? A typical TCP VISA resource would be for example:
TCPIP::192.168.1.23::6200::SOCKET
 where 6200 is the target TCP port
This is however a completely different way of programming: you would need to use VISA Read and VISA Write instead of TCP Read and TCP Write. VISA supports a configurable (single) termination character.
Paolo
Message 18 of 18
(441 Views)
