TCP connectionID not working inside the SubVI
Hi everyone,
I am working in an TCP server - client structure. Here multiple clients connect with the server. Using the TCP listener, I club 3 client TCP connectionID into an array.
When I pass this Array of TCP connectionID into subvi, put a for loop and extracting every single connectionID to read or write data, it is throwing an Error 1. But when I do the same thing inside the Main VI, both read and write operation is working perfectly. Couldn't find the way to solve.
Solutions welcome.
(3,129 Views)
Can you attach your VIs or a screenshot of them?
I have implemented multiple client architectures with passing the TCP connection ID into SubVIs which are called asynchronously and I haven't had any problems with the references being invalid inside the SubVI.
(blog)
(3,121 Views)
Are you sure the error isn't coming from somewhere further upstream, and you just don't see it until you hit the TCP functions? On the subVI, is the TCP ref array input set to required? That can help catch miswiring problems, maybe the array of references isn't actually connected to the subVI correctly.
(3,100 Views)
Extremely sorry to every one. Its just a whacky mistake. Every single time, I am sending the excessive index value (like array size is 3, but am sending 4 to index array) to an index array. So it returns the empty element from the array, that does the error.
Thanks sam_sharp and nathand for your suggestions.
(3,072 Views)
