TCP datra , send - receive - slowing down
Hi guys,
I have a problem with tcp/ip connection, it works very slowly and I cannot find the source of my problem.
I attached screen from wireshark.
10.93.1.105 - server
10.93.1.244 - client
As you can see in the pictures, when I force data to send, server responses pretty fast. But receving data in Labview works very slow(the next data is send when previous is received)
So I assume it shouldnt take more than 200ms. After 5 mins since start it takes like 1s to receive answer, after 15mins it takes like 4-5s....
Is there any leakage or I should clean buffer or what?
In read_buffer.vi you have got full structure. I have header - forces server to send size of data in the buffer, when this size is different that 0 starts to read them.
I have verifed that in wireshark, microcontroller(server) sends everything correctly, and correct size.
I attached 3 files - these show my problem.
thank you for any advices.
Message 1 of 10
(4,578 Views)
Hi Mirasoul,
  • there are lots of wait functions in your code: usually you don't need additional waits in server-client communication…
  • you are reading/writing to a lot of property nodes, the can (potentially) slow down your VI…
Do you build big arrays? As you do in that Read VI with repeatedly using InsertIntoArray with allo those hidden controls/indicators?
That would explain such behaviour…
Message 2 of 10
(4,557 Views)
first of all thank you for answer.
- meaningless in this software, it doesnt explain why it slows down in time.
- meaning less, there was not a big amount of data
- it could be it, but its not....
I send updated version. Still doesnt work correctly.
I removed all data collectors, but still wrong.
Message 3 of 10
(4,549 Views)
Hi Mirasoul,
more suggestions:
- combine your 3 TCPWrite operations into just one by appending the 3 arrays into just one. No need for those tiny statemachines to send a request to your device.
- there still are waits in both loops: 30ms in the receiver loop, 25ms in the sender loop. What's that weird coupling between the loops using a value property of that summed up enum value?
- there's no error handling in your (main) VI: do you get any errors while running the VI?
Message 4 of 10
(4,543 Views)
Unfortunately, not possible. These are procedures for Microcontroler bootloader(just simplified, to show an idea of work). So it has be in this way. ...->adress->feedback->length->feedback->data->feedback->address->...
-updated in the attached version
-none
Message 5 of 10
(4,538 Views)
Hi Mirasoul,
So why do you separate sending and receiving into 2 loops?
Why not implement a proper state machine to exactly follow those steps?
Message 6 of 10
(4,536 Views)
You can try disabling the Nagle algorithm. This will force the TCP to write the data as soon as it gets it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 10
(4,517 Views)
Where did you get this VI? It looks suspiciously like a VI that I believe to have posted somewhere around fall of last year somewhere but I can't find the post where I did that for the life of me. And I'm afraid that at least the Mac implementation might not be quite right though haven't tested that yet.
Rolf Kalbermatter  My Blog
Message 8 of 10
(4,460 Views)
Doesnt matter where he got it.
According to main subject.
I used queues to separate transfer layers and it solved problem. It was newbie problem:).
Message 9 of 10
(4,436 Views)
That's easy to say if you aren't the author.
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(4,421 Views)
