TCP log in problem
Hi guys,
I have problems regarding logging into the FTP data protocol.
I use the block "FTP put file", it works when I use the user name "Anonymous" but it doesn't work when I change the user name.
In the authorization rules I set "a" as user name (how you can see in the imagine attached).
Why I have this problem? Can you explain me some solutions?
Thanks.
(2,946 Views)
Did you try to log with another FTP client program?
Are you sure a blank password is allowed?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,919 Views)
Yes Paolo,
I tried with filezilla and I had the same error 530.
After that I tried to insert a password but it doesn't work again.
(2,859 Views)
This is definitely a problem with IIS configuration, not with LabVIEW.
Since I have no experience in creating and managing users in IIS, I cannot help you further.
Paolo
(2,832 Views)
